Hunter 23 Rudder Pintles
David Wylde
The bottom rubber pintle (pin/braket) has sheared off of my boat. Where can I find a new one? I have searched the web for a bit and don't see anything that comes close to what I have. Also, how do you replace these? I loosened the screws, but they keep turning without coming out. Are there nuts on the other side, and where are they hiding. Thanks in advance, I just bought the boat last week. David Wylde dwylde@tampbay.rr.com
Aug 19, 2005
66
NULL NULL Peoria, IL
The bolts
pass through the hull. You'll need someone both inside and outside to remove (and later install) the nuts/bolts. Be sure to use enough sealer as this fixture is very close to the water line. Where to obtain the pintle? - I don't know - maybe Hunter can help. If all else fails - it shouldn't be too hard to repair or fabricate.
