Hunter 23 Power Maintenance
Apr 7, 2015
14
Hunter 23 Lake Livingston
Howdy. My wife and I got our first boat! Score, right? I grew up with boats and she has not however this is OUR first boat. Boat maintenace is also new to us. I have an open slip at a marina and it provides power and water for a hose.
What do I do to maintain the marine battery? I have looked and searched however was hoping for a clear and concise answer. Do I need a battery tender? Can I keep it plugged in when I am away? Eventually I plan on getting a solar kit, but in the mean time, want to make sure everything is up kept.
Thanks in advance!
-na -NA Anywhere USA
Pretty simple. If your engine is electric start, it will provide a charge back to the battery when running. If you want to, you can add a trickle charge battery charger either permanent or temporary and when the battery is charged up, remove it. You can also add a battery tester or manually test it. However, do not put any battery on a continuous shore power charge as you can what we call "cook it" over a period of time destroying that battery. Always use a deep cycle battery as well and when the life of the battery is gone, good to replace it with a new one. As for preference of battery that will be your decision.
Apr 7, 2015
14
Thanks. I have been looking at solar trickle chargers/tenders. I think that may be the direction I go. For now I will probably just test the battery and charge as needed.
Kermit
Jul 31, 2010
5,669
I have two batteries and keep a 5 watt panel attached directly to each one. Keeps them charged just right. I paid about $100 each or less at West Marine. I bought the first one when I bought our H23 and it always worked. I added the second panel when we bought the H260 that has 2 batteries. You can probably get the panels now for less than what I paid.
Apr 7, 2015
14
Kermit, are the panels providing a constant flow or is there a logic board of come kind in between? Where did you mount the panels?
Kermit
Jul 31, 2010
5,669
I attach them directly to the batteries with alligator clips. Nothing in between. I set them on the companionway cover when I leave the boat. I take them off and stow them in the cabin when sailing. I'm not smart enough to figure out how or where to mount them. I'd show you a picture if I had some. Sorry about that, Chief! (Apologies to Maxwell Smart.)
p.s. You'll have people tell you the boom will shade the panel from time-to-time and they're right. But we don't sail as often as we'd like so they get plenty of sun between sailing trips. I had way more electronics on the H23 than I do on the H260 and the single battery was way plenty. I sometimes wish I didn't have two batteries on my H260. I'm not smart enough to figure out how to remove the second battery and still have the first one work. One won't work without the other.
Aug 5, 2009
333
Hunter h23 Dallas Tx.
I switched all my lights to LED's and I now have 1 Interstate marine battery. My boat is in a slip year round and my 1.5 watt solar panel always keeps my battery charged. We night sail a lot in the summer and the battery is always charged and ready.
Apr 7, 2015
14
C Jones, how do you have your solar panel rigged? Also, did the new LED lights fit in the spots that the factory lights did or did you have to do any extra work? Can you show me where you got them from?
Aug 5, 2009
333
omnivox42, Look in my profile pics for the running lights. I got all of them online and the pics tell you name brand. I put my solar panel in my port window as it faces south in my slip. One bungee holds it in and it's behind my curtain so it does not show inside. I added a female plug to my battery to plug it into.
Ward H
Nov 7, 2011
3,776
o42,
You didn't mention if your outboard has electric start & charging capability. If it does, it depends on how you use your boat.
On our O'day 25 we have a Yamaha 9.9 Electric start, power tilt and charger. When sailing we run a dedicated GPS and use an auto tiller.
Typical for us is to warm up the OB for 5 to 10 minutes, run it about 10 minutes to get to sailing area. After sailing we run it 10 to 15 minutes to get back to the slip. Hr meter usually shows .7 hr run time per trip.
We did this once a week or so with one 6 yr old battery the first season. The second season we were using the lights a bit more so I bought a charger in early Sept to top off the battery for a vacation.
We are getting ready for our third season and if I decided instead of a solar power I think I will put my money to a 2nd battery. Use one for everything and if it happens to die or gets low on charge, I will just switch to the fully charged battery.
I can then charge the low battery once back at the slip.
Dec 1, 2007
74
-Hunter -23 Kenora, Ontario, Canada
Hi, I got mine from superbrightled.com (but there are many suppliers):
http://forums.hunter.sailboatowners.com/picture.php?albumid=1534&pictureid=19022
I got the Warm White, festoon shape, I forget the length, just measure the old one in millimeters. About 1/10 the current of the old ones.
-Chris
Apr 7, 2015
14
Howdy ya'll.
1. CJones I will look at your pics thanks.
2. Ward, it is a pull start :-(
3. Chris, thanks
I see that under my fuse box I have a DC cigarette lighter port. Could I use one of the solar chargers directly into that port to charge hte battery?
Apr 1, 2007
80
Hunter 34 Nashville TN
I don't think I would use the lighter outlet. I used a solar panel clipped to the battery for years with out any problems.
Dec 1, 2007
74
Howdy ya'll.
3. Chris, thanks
I may disagree with Tommy T here, but from an electrical perspective the lighter port would be fine. There is such a low current out of a typical small solar panel that the wire size at the lighter port should not be an issue. That being said any voltage drop from the panel is critical. As far as neatness, the battery connection is best. Also if the breaker to the lighter port is turned off accidentally you come back to an uncharged battery. Hmmm, maybe I do agree with Tommy T...
-Chris
Apr 7, 2015
14
Good point about the breaker to the battery. I have an older solar charger for my VW Jetta that plugged into the DC 12V lighter port I may try as a test while docked.
