Hunter 23 mast base replacement.
Oct 12, 2021
9
Hunter 23 Santa Cruz harbor
My 1986 Hunter 23 has a taco shaped bent metal base. It's been used incorrectly and bent badly. I looked on the Hunter parts site and they have two hinged style mast base system different from my boat. I want to know if either of these hinged systems could be adapted to my boat.
Oct 12, 2021
9
You can see in this picture the mast base is a simple bent stainless steel taco. The Hunter parts catalog shows an old style and a newer style both employ installing a fitting into the base mast and another fitting on cabin top. My question is which kit would work properly on my 1986 H23?
That is a very common style
Do a Google for mast base. I bet they have it here at the SBO store. Give them a call
-na -NA Anywhere USA
You need to know which mast you have. Probably a Kenyon Isomat mast. Then call and talk with either Mike or Dave at the forum store
