		Dwight
We have been getting about 2 cups of water in the port storage compartments after about two hours of sailing.  It only occurs when we heel.  The water is very rusty in appearance, leading us to believe the water is coming from below the boat??Is there a connection to the hull at the keel that would lead to a leak while heeling?  The bolt connections stay dry...We tested the toe rail, and the fittings on the top side, with no luck....  The next step is to take the boat out of the water and inspect the bottom.Help
