I bet it looks great. Got any photos?No, I did replace parts of the sole with 3/4" plywood routed with 1/4" straight bit and inlayed with elm. Had to spend some time selecting the ply and elm to get the grain and color right. After a coating of "gun stock" stain and polyurethane it is hard to tell if from teak and holly except that it does not flex when you stand on it and it is shinny and new looking instead of old and warn. Cost was around $6/sq ft and took me an afternoon, router, table saw to get to the point where I could stain, install the "holly" and polyurethane. The poly took a week to put all the coats on all the surfaces though.
This is why I'm thinking of going with a plastic like Starboard or similar. I can replace all the floorboards and hatch boards for about $200 and never worry about them getting wet or having to refinish.We just started refinishing ours and only about 1/2 the holly is there. I think they were under water for some time. I'm going to try masking tape and some black paint over the damaged holly unless someone here has a better idea.
One of them I had to cut out the back plys and spliced in a piece of birch plywood behind the top layer of teak. That's how bad these floorboards were. I just cant spend $200+ on a new sheet of plywood.
John
That was my first thought. Go get a 24" wide cutting board and try to span between two chairs and watch it flex. I guess it would depend on the thickness. I think hatchboards would be fine. Bevel cut the edges so they don't leak, but they probably already know that.Only one caution Fly_H23
Starboard is NOT a structural material. It works great when it does not have to span more than 16 inches on center and saggs considerably at 24 inch on center. If the boards are all well supported the there should be no problem aside from some slight springyness. Once you start getting beyond 16 inch between supports it rapidly gets an unacceptabel spring in it followed by a permenant sag after the first heat wave.
That is some beautiful wood work. I'm trying to get away from the maintenance of all the woodwork, otherwise I'd just go buy a wooden sailboat. They are amazing to look at but I'm after durability and zero refinishing.
I saw a H22 for sale a few years ago where the owner felt the same way.. hated taking care of all the teak on the boat. So he painted all the woodwork blue.That is some beautiful wood work. I'm trying to get away from the maintenance of all the woodwork, otherwise I'd just go buy a wooden sailboat. They are amazing to look at but I'm after durability and zero refinishing.
