Hunter 23.5 wiring
Feb 10, 2017
9
Hunter 23.5 Milledgeville , Georgia
So how do I go about pulling new wiring in my 1994 23.5
Nov 6, 2006
10,200
A lot of the old wiring will be embedded in glops of butyl paste inside the wire "runs". This was normal practice from factory to hold things in place while being assembled.. Luckily, you don't have a lot so if you use the existing wires as a pull, it can go OK.. The key is a steady firm pull which will pull it out of the butyl after a while.. Carefully tape the new wire to one end of the old and pull it through carefully.. It is good to pull a stout nylon string (messenger line) through with the new wire so if in the future you want to run some more, ya have the pull cord already there.. You can hide the ends in the "run", just inside the pull opening.. If that doesn't work, you can use a piece of scrap lifeline from the local boat place to push through and then pull the new wire and "messenger" line through.
Feb 10, 2017
9
What about pulling new wires else where ? I want to add 12v plugs forward and aft in the cabin, also a gps right inside the companion way
Feb 10, 2017
9
I would like to add these to the asocc. toggle on the switch panel
Nov 6, 2006
10,200
Ohhhh.. Then ya need a "snake" of some sort to push through and fish out at the other end.. I have successfully used old coated lifeline .. It can be pushed, and the coating is relatively slick. Some very careful study of the boat's construction is necessary so that ya don't try to push through a solid part or around too tight a corner.. and a LOT of patience is needed to figure out how you'll twist it as ya pushing to get it to kinda go where you want it to.. I have also used straightened coat hanger wire, ... LOTS of patience. :)
