Thanks, I'll be interested to see the pics. The jib on my boat is roller furling so I was planning to use the jib halyard as the pole topping lift. So it's a matter of rigging a foreguy and some turning blocks by the aft mooring cleats. The one that I'd like some help with is the way they installed the spinnaker halyard block. For our Z-Spar mast there is a combination jib halyard, forestay and spinnaker halyard fitting which Hunter didn't use. So it looks like what they offered was an exit block just like the jib halyard block but mounted over the forestay about the same relative location as the jib halyard block below. Just wanted to see how they did it.
