Hunter 23.5 rudder
9
hunter 23.5 madison,wi
I'm a new owner of a 23.5 Hunter. The rudder had some acrylic or plastic fall out between the black plates that sandwich the rudder. It came out in pieces. I believe the tiller would move on it when you raise or lower the tiller. It was a white plastic . I'm not sure where it goes or how much area it uses. It's not shown in the owners manual. Help!
Mar 17, 2008
78
Hunter 23.5 Valletta
They are about 4 or 5 inches high and wide as the aluminium side plates. they are held by the upper bolt and the bolt that holds the tiller. They sandwich the tiller between them. you can draw them on a piece of carton and see how they fit. The important thing is that they don't overlap on the rubber friction pads below them.
Jul 1, 2010
990
Catalina 350 Port Huron
I replaced mine this summer. I used white polycarbonate, but I had one of the old ones to use as a template. They basically just need to be long enough to be held in place by the bolts and cover the tiller. You may also want to make new spacers that fit over the bolts. They're also white poly and get brittle with age.
Aug 31, 2010
29
hunter 23.5 longmont
same thing here I rebuilt my rudder last month . white delrin for the spacers and thin delrin sheet for the rudder to ride in .
I asked hunter about a set but we decided to make our own .
Gary
Likes: E.Elder
