Hunter 23.5 displacement
3,648
Not Sure What You are Trying to Figure Out
But:
Bare empty boat is 2,000#
Trailer is almost 1,000#
Junk in boat with motor on the trailer will be right at 3,500#
Oct 19, 2006
337
Hunter 27-3 Brownsville, VT/Mystic, CT
Water ballast displacement
Rick, I think he's confused by the specs page showing the displacement & ballast info. The "empty" boat displaces 2000#. The water ballast adds another 1000#, but you obviously (or hopefully!) leave that at the ramp when you tow away.
As Rick notes, when considering total tow weight load, the weight of the trailer itself & the gack onboard needs to be added in.
Benny
Sep 27, 2008
1,149
Hunter 320 Tampa, FL
Displacement and weight are two different concepts.
It is not reasonable, not practical to provide a displacement figure for a water ballasted boat with its tank empty. The boat will be unstable and not meant to be used that way. It may be done to further the marketing impression that the boat will be easily trailerable. A more responsible way would be to quote the weight of the dry boat on the trailer and not the displacement. I tend to believe the owners when they indicate the boat's is closer to 2000 lbs. I believe the difference lies in the bouyancy afforded by the empty tank vs the bouyancy lost with the tank full. Everyone seems to agree that the boat with its ballst tank full displaces 3,000 lbs before motor and goodies. So for towing purposes I would take the owners indications of 2,000 lbs plus 1,500 lbs the weight of trailer and another 300-400 lbs of goodies. Your towing weigh will be close to 3,800 lbs. You should take the rig to a weigh station and have it weighed. Not a smart claim by Hunter in its brochure.
