Hunter 23.5 D/C switch panel needed
Jun 3, 2004
134
Hunter 23.5 Cape Cod, Ma.
Anyone know if the original D/C switch panel is available for sale anywhere ?
I have 12 volt power from the battery to the panel and all the fuses are good but none of the switches turn on the interior or running lights. Several feel stiff and possibly corroded internally ?
Could new switches be installed in the old panel and are they single or double throw ? Not too electrically minded.
Thanks for any replies.
-na -NA Anywhere USA
@Mike in Cape Cod
You will not be able to replicate that specific panel. There is an easier way. Simply replace the switches or breakers from the panel and put new ones in. On the breaker look at what amp. it is so you order the right ones. The ones you will need are manufactured by Sierra and not sure if the forum store can get them but West Marine does. You may have to order them though if not in stock. Hope this helps. If you have 5 amp breakers needed, I have 5 in my possession. Send me a private email. Hope this helps. Just did this to Kermit's boat that got fried and repaired.
