		Debo Cox
I'm going to be hauling my fixed keel 22 out for a bottom job later this summer. There's a small access port under the steps that I assume is for the back keel bolt. Am I correct in assuming (no jokes) that to access the other bolt, I'll have to remove the table from the center trunk?Next question. There's always about a quart of water that is in the bilge under the floorboards. I mop it up - next time I check - it's back! Is this "normal" (anything to be concerned about? Thanks.
