Hunter 22 bilge pump location question
161
Ericson 25+ Watkins Glen
SenecaDaze, any other pix you need of my setup?
thanks for the pics , im all set up, i tied my bilge pump into the cockpit cooler drain ,wont be using cooler for cold ones,using it for docklines and other gear.
SeaTR
Jan 24, 2009
408
Hunter 22 Groton
SenecaDaze,
Doesn't your cockpit cooler drain .. drain into the cockpit ? (mine does) IF so, do you really want to have the bilge pump discharge into your cockpit (oil, dirt, grime and all) ?
Just a thought..
Sep 25, 2011
161
SenecaDaze,
Just a thought..
oil,dirt ,grime??? if my bilge has them i suspect a more serious problem.
besides most comments i have heard about the bilge on the hunter 22 is how dry it is.
Cockpits need cleaning on a regular basis anyhoot.
There will be kids,a dog and probably unwanted seagull leftovers.
cleaning does not bother me.
mel22
Oct 1, 2010
66
Hunter 22 Lake Dardanelle
hunter
This is the way I found my cockpit drain lines in my H22. You can see the leak at the bottom of the tee assembly.
I have had a few boats and really like my H-22 but when I see things like that it makes me question what the quality controle was doing or not doing. I have seen or heard of so many questionable practices by the boat industry I serriously doubt I would ever spend money on a new boat. I had a Carver 28 voyager one time and the wood work for the engine logs had to be designed with one thing in mind, failure in a few years.
Any way as sailing goes I find the H 22 a great boat to often overlooked.
Good Sailing.
