Hunter 21.2
Nov 6, 2013
1
Hunter 21.2 Mobile, AL
Hello, I'm considering buying a Hunter 21.2. I'm going to have to trailer it about 400 miles to get it home. I have a 2010 4cy Nissan Frontier truck. It's within the tow capacity for the vehicle, but I wonder if it will really be adequate for towing, lauching, etc. especially with a manual transmission. Any advice /comments are appreciated!
Thanks
Sep 3, 2013
146
Hunter 22 Lake Eufaula
Hi Steve,
We have a h22 85' model, and we pulled just fine with a Nissan Murano, it's 6cy but you should still be ok... I wouldn't want to pull out of the water with the manual trans. And I wouldn't do over 50mph on the hwy with it... Ours felt shaky over 45... We have two axels on our trailer if that helps.
Jul 12, 2011
1,165
Leopard 40 Jupiter, Florida
Trailer
My principal concern would be the trailer, rather than the tow vehicle, for such a light weight boat. I bought a similar boat (H216) from a local experienced sailor. Apparently boat and trailer maintenance don't go together. The bearings had never been changed or greased; just water and rust. If you're buying out of town, and don't know how, I suggest your first stop is a local tire dealer/mechanic. For about $50, I get my bearings and tires inspected & greased; a good annual investment. Also, check your tie-downs and security of the rigging etc. that it can withstand 70mph. On the way home, I agree with the recommendation to take it slow, and then to stop after first half-hour to put your hand on the bearings to check the heat (should be just warm to the touch, not hot).
-na -NA Anywhere USA
Parsons is correct that many do not take care of the trailer like the boat. If not mistaken, I think the trailer came from Magic Tilt and probably has grease fittings on the hubs. If so, you can apply grease. I would also tighten the lug nuts and make sure the tires are at proper inflation or PSI which can be read on the tires. I would also inspect the bolts holding the axle to the trailer frame if not welded. Then take the boat down the road for about 10-20 miles suggesting that the owner use his own vehicle. Usually if the bearings are bad, they will heat up quickly and you will notice it within the first 10-20 miles of towing. You will notice a slight heat but if excessive, then the bearings are bad.
As for the tires, if worn, dry rot, parts torn off, etc, then new tires would be warranted. Make sure the motor is off before transport and I would strongly suggest a tie down on the back. When you put the strap over the boat, cushion it with for example a piece of carpet with the carpet face down on the boat as you are dealing with composites vs. fiberglass. Twist the tie down once or twice from the deck to the trailer which will keep it from flapping in the wind and make sure you do not over tighten it either.
Aug 5, 2009
333
Hunter h23 Dallas Tx.
All of the above and pull your wheel hubs and repack the bearings no matter when they told you it was last done.
Jan 18, 2013
10
Hunter 216 Jervis Bay
Thanks
Hi
Not sure how comparable, but I have a 216 that I have been towing with a Subaru 3.5 Outback since 2006. Some trips of 180 kilometres. Many trips of 20 km. Loading and launching a breeze.
Hope that helps
Michael
