Hunter 2004 386 LE Calibrate tank monitor?
cbader
Sep 25, 2008
15
Hunter Legend 386 Richmond
Is there a way to calibrate the tank panel reading. I had the sensor replaced since it was only showing four bars in the diesel tank setting and I think I need to calibrate the display after it is full. It currently only shows 8 bars and I think it should have ten showing or am I mistaken. I have the same issue on the water tank when it is full it only shows eight bars not the ten I can see. Any help would be appreciated. I have tried hold the C button but doesn’t seem to do any thing. There is no documentation i can fine on boat or interne.
Jan 4, 2006
7,870
We'll need the name and model of the readout instrument as found on its face or a photo of same. If nothing is showing, pull the instrument from the panel and get the info from the rear.
Marlow-Hunter changes their instruments every few years.
cbader
Sep 25, 2008
15
So looks like it is the Snake River model of panel. I am going out to boat today and I found instructions on how to calibrate I will give it a try. I hope it works.
