Hunter 140, 146, 15,170 questions?
Apr 12, 2016
2
hunter 146 Chicago IL / Delavan Wis
Good Morning, I am looking for information on a 2003 hunter 146, I bought one and it didn’t have sails or rudder. (looks like the 140, 146, 15, 17 are basically close in sizes)
I have some sails and a few rudders that I might be able to make work.
a) Where can I get specifics dimensions for the stock rudder height width, length that is under the water …does a flat aluminum (+/-1/4") rudder work different the the wood (looks like the stock one)?
b) also the sail dimensions for main and furling jib… does it use slugs or rope on the mast…
c) is the foot of the main sail loose on the boom I assume loose?
d) What is the dimension for the wire luff in the jib?
e)Also can If I relocate the forestay tang on top can I put a larger jib?
f) If I cut down the sail I have and make the roach larger on the main (making more sail area) would that increase performance or make the boat unbalanced?
g)I want to put spinnaker on too. the 15 and 17,I believe has a kit but doesn't give dimension to mount the halyard pulley? any thoughts, anywhere between the jib and top?
Thank you for any information you can provide,
Rich
