Hull Wax Removal
Magothy Boy
I am going to be waxing my hull during haul out in August and I am interested in any one's experience with non-abrasive methods of removing old wax from the hull. I know that I can use polish and or very fine (like 2000 grit) wet sanding to do this but I was hoping for a method that would not remove any gelcoat. Thanks in advance for any insights or replies. Kevin
jimq26
Jun 5, 2004
860
I think Steve means PoliPrep
It will easily remove any residue wax that UV hasn't already taken care of. Wax generally only lasts 3-4 months before the sunlight degrades it.
RichH
Feb 14, 2005
4,773
If you mean 'real wax' .....
any 'strong' detergent will lift old wax. TriSodiumPhosphate (TSP), Sodium Silicate based detergents, etc. all remove wax.
Magothy Boy
3M Hull Wax
I used 3M hull wax and it has been on the hull for a year. Kevin
Dan
Jul 26, 2006
190
Hunter 420 Stamford
I wax after every sail
that got your attention, didn't it!? I use a hose attachment that sprays wax as I hose down the boat (it's made for car waxing, but the boat doesn't know the difference). That way I keep the hull coated and protected. I haven't seen any downside -- as far as I can tell.
