Hull thickness
K
Kurt Myers
I'm mounting two transducers on my 22. My plan is to mount them in the V-berth area just aft of the water tank on either side of the center line.Does anyone know the hull thickness at these points? The transducers can handle up to 3/4 of an inch.
Jun 2, 2004
1,438
Oday 25 pittsburgh
I think you will find
That in that area, the hull thickness is from 1/4" to 1/2" thick. Please remember I am speaking of the 22-25' O'Day's with CB's. My guess is that is is still in that range. To be sure, drill a 1/8th" pilot hole to see what is there. Repairing a 1/8th" hole is much easier than a 2" hole in the hull. I think you can be confident that it will be about 3/8" think. Make sure you put it on a flat surface. If you try to put it on the centerline, you will not get it sealed properly. I think you are making a good choice in your placement. r.w.landau
K
Kurt
Thanks
Thanks for your input. It's a new boat to me and drilling holes in it's hull keeps me up at night.The weather this week is looking good,I should have them in by Wed.
K
Kurt Myers
Success
It was alot easier once I got over the drilling the hole thing. I mounted them about 6" either side of the centerline, on a nice flat area. The hull was about 3/8" at this point so it was no problem. Thanks again for your info.
