hull thickness
C
christopher bayer
i have heard some disturbing commentary about the hunter hull on the 420 model. how thcik is the hull so to speak. a friend of mine kidded me and said you can read a newspaper that is outside the hull if you are inside. is the hull that thin ? what is reality here? please advise. i am considering purchasing a new 420 at the annapolis show in two weeks. thanks.
Paul Akers
Check in Annapolis
Hopefully, there will be one to look at in Annapolis. Check it out and put the question directly to the agent. What better opportunity to find out yourself than to get the word by hearsay? Although comments from owners, I'm sure, will be a more convincing factor. Also, go to the Owners' Directory on this site and contact some of the owners directly for their comments. Good Luck nn your decision.
Joel
Thickness isn't a concern.
While at the show, lift the floor boards and pull out a transducer. Will give a good representation on thickness. P456/Song of Texas
Rick D
Jun 14, 2008
7,208
Nonsense, Christopher.
'They' used to say the same thing about O'Days, Columbias and, more recently, Catalinas. Besides, if you can 'see' through a hull, it just means there isn't a core material. That is, it's solid glass. You can see light through most solid glass laminates. Rick D.
Peggie Hall/Head Mistress
They used to say the same thing about Bayliners
What you're hearing is just "brand bashing" from people who don't know the first thing about hull construction, but like to pretend they do...so they parrot other "brand bashers." If you were ask 'em what type of matting or roving is used in Hunter hulls--or whether any is used, they wouldn't even understand the question, much less know the answer.
Jul 1, 1998
3,062
Glass Bottoms?
You know why Bayliners are going to come out with glass bottoms? Ans: So they can see last years model! Originally told to me by a power boat salesman.
