on my 9.2A when i put some through hull fittings it is 9/16 to 5/8 thick...but around the stuffing box tube that goes through the hull it was about 3/8 thick at the thinnest part...i would think that there is no much differance in the two hulls are close in size.... you cane always drill a 1/8 hole in it and see how thick it is with a 3/32 welding rod ..and then fill it back up with marine tex or thickened epoxy if it is some thing you have to be totally sure about.....Is anyone aware of the hull thickness for this model?
Thanks.
get the through shoot through one and mount it with a toilet bowl wax ring and see if it will work and if not exchange it for a through hull one ......Thanks! I am debating between a thru hull and shoot thru the hull transducer. It has 1 thru hull already for the datamarine depth finder, but I want to add another more modern depth finder/gps combo. I would like to leave the datamarine installed as a backup. The shoot thru hall transducer I found has a "limit" of 1/2 fiberglass. So that is the nature of my inquiry.
Thanks again for your information.
