Hull stripping
Mike Casucci
Does anyone know of a someone who will strip the bottom paint off using walnut shells in the Stratford, CT area?
Bob
Check with Brewers
Check with the local Brewers yard, I believe there is one in Stratford. I do not know if they do it but Brewers Yacht Haven in Stamford does. Not cheap but much better then sanding. I have sanded down to glass on my previous boat and it was no fun.
John Dawson
Walnut shells
Is that safer than sand blasting? Does it avoid pitting, etc.
Dec 2, 1999
15,184
Soda blast.
I think the best method of paint removal by blasting is Soda Blasting. I would think that walnut shells are also going to be fairly hard on the gel coat. If the person doing the job is good, I would assume that sand is also fine (IF THEY KNOW WHAT THEY ARE DOING).
