Look at the engine specs too.
Depending on which motor you are going to purchase, you should check out the specs. For instance, if you are going with a Honda, the 8 and 9.9 weight the same. So going with the 9.9 to give you the little extra (25% increase) in power may be worth the extra money. If you can get a smaller engine that weighs less then that may be the way to do.Smaller engines will usually do the job unless the going gets rough, then you need that little extra boost. Also the long shaft is going to usually work better than the short shaft. When it gets lumpy the short shaft is out of the water as much as they are in.Also be sure that you get an engine with a charging source. If you don't have a solar panel, then you have no other source of recharging your battery bank.
