With all this hull number expertise here, can someone explain why my 1983 C30 has two different hull numbers? The number embossed into the hull (factory) and the number on the plate in the cockpit are several hundred apart.
That's what I've been doing, I'm just curious as why there is such a large discrepancy (over 200) between the factory embossed number on the outer transom and the factory number plate in the cockpit.
Does the title jive with the engraved number on the hull? Those plates are easy to remove. Mine is in our nav station at the moment as I removed it to paint. I wonder if Catalina would make you a new one that is correct.
