Hull number
7
cape dory 28 28 Annapolis md
The hull identification on my recently purchased Pearson 33 reads:
DLZAM0620587 Will someone please tell me what these letters and numbers mean?
Apr 15, 2009
302
C&C 30 Annapolis
hull #
That doesn't look right unless this is a very old Pearson built before hull numbers were standardized. I'm pretty sure an 80's or later vintage Pearson should have a hull# that starts with PEA.....
Apr 8, 2010
2,255
There are quite a lot of threads here and round the net on how to translate a Hull Identification Number.
"HIN"
Some site searching is in order.
LB
Feb 6, 2008
7
I forgot to mention that my Pearson 33 was built in 1972 at least that's how the title reads. It has a Zanmar engine although the opening to the tank reads GAS.The previous owner installed the diesel engine some years ago. The engine control panel is located on the stbd side forward of the locker but the engine speed and gear throttle is located about 5 feet aft also on the same side. My first project next spring is to relocate the engine control panel aft.
CalebD
Jun 27, 2006
1,479
Tartan 27' 1967 Nyack, NY
1972 was the change over to to using VIN on cars with boats to follow shortly. There will be no title for a car or boat pre-1973 vintage.
I'm not sure when Pearson started putting HINs on their boats but there was no need to until 1973 when Titles became the law = the Title necessitated the HIN and VIN.
Could very well be a made up HIN that you have.
RichH
Feb 14, 2005
4,773
There 'should' be (or was) a cast bronze plate just below the entry to companionway ... listing/showing your Hull Number:
Pearson Yachts
#XXX
Portsmouth, RI​
CalebD
Jun 27, 2006
1,479
RichH is correct (as usual). Even my 1967 Tartan 27' has a hull number on a bronze plaque over the companionway but has not 'real' HIN.
Feb 19, 2011
1
Oday Day sailer Ipperwash
17' O'day Daysailer
any one know where I can get info on my boat?
O'day (Canada) LTD.
Brampton, Ontario
Made in canada
Hull No. 21474 Class No. 3946
