Hull number decipher?
eliems
Apr 26, 2011
102
Hunter H28 Port Moody
Does the Hull number tell you year/model/etc like a car?
Mine is
14K39717 and I want to know the year of manufacture as I thought it was a 93 but the surveyor thinks it is a 95.
eliems
Apr 26, 2011
102
Sorry ... that was not the Hull #, it is
HUN28271G295
Thanks
Oct 22, 2005
257
Hunter 44DS Redondo Beach, CA
It that is actually the number, you might want to check with Hunter, either someone has altered it or they made a mistake when they initially stamped it at manufacture.
MrUnix
Mar 24, 2010
626
Hunter 23 Gainesville, FL
Are you sure that last "2" is really a two?
Based on that HIN, your boat is a:
Model year 1995 Hunter 28
However, the "G2" seems to indicate a date of mfg. as July 1992?!?
Maybe someone can elaborate further :confused:
Cheers,
Brad
BoatSafe HIN description
eliems
Apr 26, 2011
102
According to the PO the Surveyor misread the last # which should be a 3 not a 5. I am going out to the boat tomorrow and will check for my self.
Sep 26, 2008
566
- - Noank CT.
Figure 2 - HIN Format After August 1, 1984
"Boats manufactured or imported on or after August 1, 1984, also have a duplicate secondary HIN affixed somewhere on an unexposed location inside the boat or beneath a fitting or item of hardware. The purpose is to help authorities identify your boat if a thief or vandals remove or damage the primary HIN on the transom. It is illegal for anyone (manufacturer, dealer, distributor, or owner) to alter or remove a HIN without the express written authorization of the Commandant, U.S. Coast Guard."
According to this info call Hunter, maybe they can tell you where the second hull number is located to verify correct number. I suspect a phone call to Hunter could also help figure out the number based on hull number and model. I suspect Lee is correct that your boat is a 93 since they changed the model identification in 1995.
