Hull Liner
I've started getting the old foam lined cloth liner off the hull, but I'm not finished yet. I've only been working on it a couple of hours so far, and I'm about half done. I got a grinding wheel to put on my drill and used it. This is a "Paint and Rust Remover" from "GatorGrit" that I picked up from my local hardware store. It's basically a sponge-looking wheel that's very stiff, that's meant to take off paint and rust. It's been very "kind" the fiberglass, with minimal grinding of the fiberglass.It should be noted, this is not completely removing the foam liner. Keep in mind, I don't plan on repainting this, but will put foam insulation over it, so it's not essential that it be bare fiberglass. When I'm done, I plan on using "goof off" as suggested, to see if that gets the remainder off
