Tony Belcher
Hi - I am doing a search to see if anyone has experienced a problem or knows someone who has experienced a problem, with an indentation appearing on the hull below the waterline,on the port side, about where the head is located (on a 1991 Hunter 30T). On my hull it is concaved about two feet in diameter to a depth of about one and one-half inches at the center. In particular, when the boat is out of the water in a sling or on a cradle, and did it go back to shape when back in the water? If you have: What was the diagnosis of the problem? What was the fix? What support did you get from the manufacturer and/or the dealer? I would appreciate a quick response on this query, thanks.
