I bought a Mac 25 yesterday.Didn't realize it had structural hull damage, Is super lightweight Boat can't find much structure on the inside
See what it looks like after you launch her. Macs will "oil can" on the trailer.I am gonna have to learn how to do some serious fiberglass.
Thankyou so much!! No Matter what the cost.I want to make it stronger.Any advice would GreatI think you are okay. I've owned a few macs (and many other boats) and they will tend to sag if they sit a long time on the trailer. But pop back into shape in the water. I would launch her someplace where you can let her sit in the water for a few weeks. During that time, add some support on your trailer. If the hull does not go back into shape by itself, you can probably jack it back into place using a long jack against the cabin top... then glass in a stringer on the hull sole for stiffness to keep the hull in that shape. If you need help with fiberglass techniques for stringers... this is the forum for that too.
I panicked when I seen it on the trailer.And now I'm come to realize it's typical.Thank you.I will make it stronger thoughFirst boat was a '78 Mac Venture 25. Would oil can sometimes even while in the water going through some rough seas. Scared the crap out of me initially. Learned that this was pretty normal given the light displacement, 2300#, I believe, to make it easy to trailer. Never gave me a problem, though. As I gained more experience and started to venture further out, I realized the need for something a bit beefier. The V-25 did a good job at what she was built for. Go sailing.
Once the hull is in the correct shape... you can add a stringer to make it rigid by laying a piece of something (does not matter what) in the shape of the stringer and then glassing that in place using wetted fiberglass cloth. I recommend using epoxy resin here. The strength comes from the fiberglass so the piece of something is not that important. But somethings are better than others. If you use wood, you will want to first coat it in resin to help it resist rot. If you use foam (like a cut piece of swim noodle) make sure the foam you use is closed cell foam. A swim noodle is closed cell foam. A ripped small diameter piece of PVC pipe is also a good choice ... but foam is easier to shape and glue to the bottom of the hull.Thankyou so much!! No Matter what the cost.I want to make it stronger.Any advice would Great
Thankyou so much !! Cant wait to work on it ! I am in Northern Mi its snowing!Once the hull is in the correct shape... you can add a stringer to make it rigid by laying a piece of something (does not matter what) in the shape of the stringer and then glassing that in place using wetted fiberglass cloth. I recommend using epoxy resin here. The strength comes from the fiberglass so the piece of something is not that important. But somethings are better. If you use wood, you will want to first coat it in resin to help it resist rot. If you use foam (like a cut piece of swim noodle) make sure the foam you use is closed cell foam. A ripped small diameter piece of PVC pipe is also a good choice ... but foam is easier to shape and glue to the bottom of the hull.
Once you have identified where the stringers need to go, clean the hull in that area very well. Scruff it up with some sandpaper and clean again.
Done!
- Glue down the form you choose for you stringer.
- Get a piece of visqueen (plastic sheeting) and cut it about 6" longer than your stringer and about 6" wide.
- Cut out six rectangular pieces of fiberglass cloth. Each retangle will be about a half inch narrower and shorter than the previous. The smallest will be wide enough to cover the stringer form and touch the hull bottom by about an inch on all sides. Each successive piece of cloth will overlap the previous by about a half inch.
- With the plastic sheet on your work bench, lay all of those pieces down on the plastic sheet with the largest on the bottom and the smallest at the top. (this will be reversed when you lay it on the stringer--- read below)
- Completely wet all f the pices of cloth with resin and then squeege out the excess resin.
- Lay the plastic sheeting over the stringer form so that the smallest piece of cloth is laying against the stringer form.
- Use a squeege against the back of the plastic sheet to work out the air bubbles and then leave it alone until the resin kicks and hardents. The plastic sheet will peel off easily once the resing is cured.
You can buy squeeges from any hardware (or even Walmart). They look like this
... and I also like plastic putty knives like this...
Jamestown distributors is one of my favorite places to buy fiberglass cloth and resin.
You will have to wait until the hull is warm enough to fiberglass. The reaction will not kick if it is too cold and you will have a mess to clean up. Jamestown products come with exact instructions that tell you what the hull temperature will need to be. The last time I ordered product from them, they actually called me and talked me through my order to make sure I was getting the most appropriate product for the project I was working on (a strip plank canoe). They have great tech support.Thankyou so much !! Cant wait to work on it ! I am in Northern Mi its snowing!
Jamestown is a great company to do business with, however, for paint and resins it is better to do business with their subsidiary TotalBoat.com. A more limited selection of products than JD which focuses on a broad range of boat building products.You will have to wait until the hull is warm enough to fiberglass. The reaction will not kick if it is too cold and you will have a mess to clean up. Jamestown products come with exact instructions that tell you what the hull temperature will need to be. The last time I ordered product from them, they actually called me and talked me through my order to make sure I was getting the most appropriate product for the project I was working on (a strip plank canoe). They have great tech support.
The cooler you work, the longer the resin takes to cure...and the longer you have to work with it (less of a rush)... so there are advantages to working on the coller side of the acceptable temperature range. If you have any heat lamps, that is also an option. You can pre-warm the area of the hull with the lamps... do your work in a cool shed or garage... get everything wetted and sqeeged and then set your wetted cloth in place and warm that with the lamp also.
I will definitely wait for warmer weather. Thank you so much.You will have to wait until the hull is warm enough to fiberglass. The reaction will not kick if it is too cold and you will have a mess to clean up. Jamestown products come with exact instructions that tell you what the hull temperature will need to be. The last time I ordered product from them, they actually called me and talked me through my order to make sure I was getting the most appropriate product for the project I was working on (a strip plank canoe). They have great tech support.
