Jeff
Sail Magazine's Sept edition has some great info on how fibreglass boats are built and a list of questions boatbuyers should ask about hull construction. Does anyone know if Beneteau (or other builders like Hunter and Catalina) have detailed info available on their hull construction materials and techniques to allow a purchaser to assess and compare build quality. Questions I'm looking for answers on are on things like:What is the Gelcoat/exterior finish above and below the water line?What is the principal resin used in the hull laminate ie. epoxy, vinylester, etc.How are the hull and deck laid up? ie. vacume bagged, CSM, chopper gun, etcWhat is the predominant hull material used ie. unidirectional, biaxial cloth, woven rovings, CSM or Chopper Gun? What is the fibre/resin ratio? ie. 70%, 50%, 30%How are hull-to-deck joints sealed? What is sealant?What mechanical fasteners are used and on what spacing? bolts, screws, rivets, etc. If anyone has any insights on this info and where to get it, pls advise, thx.
