Hull cleaner
7
Hunter 36 Toledo Beach Marina -Lake Erie
Has anyone had experience with this product? It sounds pretty good. I have some black streaks down the side of my boat where the debris washes when it rains. It's quite unsightly and I want to make sure I clean it all off before I wax it. When it was in the water last summer I tried to clean it with several things that didn't get it off. http://www.nuhull.com/ They also have a product on this site called Champ - which is also for cleaning. Not sure what the difference is between the two.
7,690
Alden 50 Sarasota, Florida
slick marketing
couldn't find an MSDS to identify what it is which is usually a good indicator they don't want you to know. Unless you get a real perosn to tell you this stuff works, I'd suggest you try FSR which works great ont almost any fiberglass gelcoat stain
Feb 6, 1998
11,759
Sounds like...
Sounds like a well marketed "Ginsu" version of On & Off! I'm guessing it costs more than On & Off too! BTW On & Off is less than $15.00 for a Quart even at West Marine.. Similar products Star-Brite - EZ-ON / EZ-OFF Mary Kate - ON & OFF and ON & OFF Gel Davis - FSR (gel based) West Marine - Fiberglass Stain Remover (Gel)
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
I had a C and C some years ago
that had a black anodized toe rail. It always produced black streaks running down the topsides. I found that Starbrite "Black Streak Remover" worked well in getting rid of them. I later found that sanding, priming, and painting the the old toe rail with Rustoleum worked even betterr...
higgs
Aug 24, 2005
3,736
Nassau 34 Olcott, NY
Streaks
I have found McGuires 50 one step cleaner/was mixed with a little elbow grease takes care of spots like that for me.
Rob
Use Fantastic
I've used Fantastic cleaner, the stuff your wife uses around the kitchen, it works like a charm removing those black streaks. However, it also removes the wax from the boat so you must re-wax the boat or section after using it.
John
Jun 3, 2006
803
Catalina 36mkII Alameda CA
scouring powder
Before using Poli Glo on my boat, I removed some black streaks with simple scouring powder. In a few instances, I also had to use some of that green pad material, which did remove the wax, but it didn't matter since I was refinishing the hull anyway. I'm increasingly coming to the conclusion that a lot of products marketed to boaters have very simple, waaaay cheaper alternatives.
RichH
Feb 14, 2005
4,773
The BEST hull cleaner / gelcoat cleaner Ive ever found ....
Is a product called Tuff-E-Nuff. A Florida made detergent that 'was' common in chandleries on the East Coast - Worst Marine used to carry it. Its a sodium silicate based detergent. It removes dead wax, air pollution specks, fungals such as 'artillery fungus' --- those zillions of teeny black specks that show up after a long wet period, removes blood by dissolving the cells, etc. I also use it to clean my sails. It will kill and DISSOLVE mildew on contact. However be pre-warned that it will deeply penetrate into porous gelcoat, and briefly turn the gel 'yellow' as it dissolves the old dead wax, etc. in the gel pores ... but will soon return to the original gel color. Stuff is expensive but you dont need much. It will also 'etch' bare teak so be careful if you dont intend to clean/etch your bare teak. Its highly caustic so use precautions.
May 23, 2005
7
Thanks
Thanks to all for your help. I'm so excited for spring that I'm anxious to scrub my boat!
