How worried should I be about this leak?
Alctel
Dec 13, 2013
264
Hunter 36 Victoria
I have a leak in this old plastic transducer that is mounted in front of the port water tank (the one under the sofa).
It is currently leaking, and running into a couple of holes in that area that lead down to the bilge.
I can't get it hauled until Monday - my question is, after it's hauled, do I have to worry about any internal damage from the stream of salt water? It's been going around two weeks. I have no idea what that portion of the boat that leads under the floor to the bilge looks like.
kito
Sep 13, 2012
2,011
1979 Hunter Cherubini 30 Clemmons
Don't worry....that's what the bilge is for. The hull is not cored. Any leaks will run to the bilge without damage. Just reseal your through hull transducer when on the hard.
Jun 5, 2010
1,136
Hunter 25 Burlington NJ
Use heat and an old-but-sharp chisel to remove the transducer. Saw 60- or 60-grit paper up and down in the hole till you see (mostly) bare 'glass. Epoxy the edge. Reinstall with 5200.
Takes me about 45 minutes. :)
