I've searched all through the forums and see many posts on isolators and combiners, but I don't see anything that answers my question. I have a Hunter 340. The battery selector is mounted inside one of the lazarettes which requires you to practically climb in to actuate it. I would very much like to find a solution that will automate the battery switching, avoiding the need to use the switch regularly. Current setup is 1 starting battery on 1, 3 deep cycle batteries for house bank on 2 with a 1,Both,2 battery selector switch. It is necessary to switch to back 1 to start the boat and then back to 2 after the boat is started to prevent running the starting battery down...2 lazarette dives per start.
I have chartered boats for which everything runs off the house bank until you start the engine. As soon as the starter load is sensed, the starter battery is paralleled in and is re-isolated after the engine starts. It also automatically charges whichever bank requires it from either the alternator or shore power charger.
Does anyone have this kind of setup? What type of equipment do I need? I've talked with Hunter and a couple of the combiner manufacturers and either they don't have a product that does this or they don't understand me.
Thanks, Ted
Thanks, Ted
