I have noticed that as our ‘08 h36 ages the bulkheads creak more. The sound seems to emanate from where they are seated in the fiberglass grooves in the hull. A little annoying while at anchor in light, rolling waves. Any ideas on how to quiet the creaking? I was thinking about spraying sailkote or a Teflon dry lube along the bulkhead/fiberglass joint, but wanted to see there is a better way. I think the bulkheads are just set in place With no/little glue, and are held tight when the deck was bonded to the hull.
Two other places this boat creaks are under the mast foot articulating joint (I dump water on it to stop that), and where the main sheet exits the boom (the sheet creaks as it slides on the polished insert in the boom opening).
Thanks All
Dan
Thanks All
Dan
