Mike G.
Hi all,I know the weather is still iffy to say the least up north, and ice-out hasn't happened probably yet on the small Michigan lakes, so wanted to send some inspirational thoughts of summer your way.I took the 170 out for a great 5 hour sail on the lake yesterday. Putting in at the ramp, the water was still chilly-- "only" 65 degrees-- but again, this is relative. Motored out the channel from the ramp and into Lake Santa Fe around 11am- slight patches of breeze- cut the motor and she ghosted along assuredly. By around noon, the southeasterly breeze had totally filled in. Tacked back and forth across the lake a few times (it's 3 miles long but only 2 miles wide). The breeze came up to about 10-12mph and I actually considered reefing the main as gusts proceeded above that speed- but didn't. Just trimmed the jib flat, sat up onto the windward rail and carried on- spilling the main some as the boat heeled past 20 degrees. We topped out at around 86 degrees for air temp- with mostly sun ducking occasionally behind some fair weather clouds. Like a summer day on the Laser at my parents' lake house in Minnesota. Had a great time, and speaking of up north, spotted several common loons on winter vacation from the great north.On to my question- Does anyone have an efficient way to keep the 170's sails wing on wing during a downwind run? I was running yesterday before the breezes filled in and the jib would often jump back to the lee side- shadowed by the main. Any suggestions (aside from the obvious: obsessively checking astern to see what the shifting wind's doing every instant)? Thanks for any suggestions, and happy spring (next week)!Mike G.
