Hi- am just getting sails on and replacing running rigging on my new to me Hunter 37 cutter. I have two large cockpit winches, and a single port side cabin top winch. Trying to figure out sheets, especially the staysail sheet which is lead aft along the port rails. Obviously the yankee goes to the cockpit winches and turn blocks right behind the winches. The main sheet is led so that it terminates on the port side for the cabin top winch. IF I'm running the Yankee and the staysail, and the Main I appear to be short one winch, which could be located on the starboard cabintop. Let me know how you cutter owners are running your control lines, where you terminate the mail sheet, and the staysail sheet.
Thanks,
Paul
Thanks,
Paul
