How to replace potable water tank
AlainC
Mar 17, 2013
7
Hunter 30 Vancouver BC
I need to replace the existing aluminum water tank on my 1989 Hunter 30. It was placed was the boat was under construction and therefore it seems to be a major job. The tank is a 40 Gallons tank.
Assuming I don't want to remove all the wood around the side and top of the tank (I have a 17X20 opening hatch access at the center of the tank and the tank is 16" wide, 16" deep and its length fit the hull shape.)
1 Has anybody replaced a water tank on this type of boat? if so how did you do it and what did you replaced it with?
2 I am planning on cutting the existing aluminum tank so that I can take it out from under the V Berth. Is there an easy way to do that? Any particular safety caution I should take?
3 What type of construction would you replace the tank with ( hard Poly, aluminum or? flexible.) I am leaning towards a hard Poly tank.
4 If I go with a Poly tank any suggestions on how to secure it to the boat (I want to put it in the same place as the existing tank). I am planning on using a rectangular tank say 28L x 16W x 20H and would need to somehow secure it to the port and starboard sides. (Right now the aluminum tank fit the shape of the hull.)
Thanks for any advice.
Aug 12, 2014
33
Hunter 33.5 Sackets Harbor
Wow, I replaced my tank in my 33.5 and it was a major job. I replaced it with a hard poly tank and I sized it so it fit through the companionway and then inside the remains of the galvanized tank after I had removed the top and baffle. Much bull work cutting up the top and removing the welded baffle. After that I foamed it into place. Best of luck to you
Oct 24, 2010
2,405
Hunter 30 Everett, WA
We have a 1989 Hunter 30 with a plastic water tank. I will try to get some photos today.
Ken
Jun 28, 2009
33
Hunter 27 Penobscot
I have a similar problem in my Hunter 27, is putting a bladder in the existing tank an option? If so how much of a job?
BF
Oct 24, 2010
2,405
pics
Okay here are a couple of pics. In my case the tank is held in place with expanding foam and some strapping tape. I assume the strapping is to hold it in place while the foam sets up.
I assume the "V" birth floor must have been removed for access.
I also see that there is more storage forward of the water tank that I didn't know about.
Ken
2,405
Give me a shout if you want to drive down and have a look for yourself.
Ken
Jun 5, 2004
12
Hunter 30_88-94 Poulsbo, WA
I just replaced my fresh water tank on my 1989 Hunter 30. I used the Ronco tank number B431. It was a little smaller ( about 35 gallon) but an easy fit. I removed the aft bulkhead under the v-berth and left the top of the v-berth in place. I had to cut some fiberglass tape and remove the closet to get this bulkhead out. With this bulkhead removed I was able remove the old tank and install the new one. Under the old tank is a 3/4 plywood deck that you can use to fasten lumber or hardware to help keep the new tank in place.
