How To Replace Lenses on Gray (Bomar) Portlights
Apr 22, 2011
971
Hunter 27 Pecan Grove, Oriental, NC
You can order online at the link Claude gave if you have an ‘83 - ‘87 Hunter 31 these are your ports you can buy parts or the whole port. Not sure if they are working now. Try an email, I have found them to be most helpful. I am slowly replacing my ports an have ordered four from them so far.
Ports- Gray Enterprises
Odd port 14.75 x 4.75 Size 414
All others 12.5 x 5.75 size 512
I bought my lens there also. They have them in clear or tented.
HMT2
Mar 20, 2014
900
Hunter 31 828 Shoreacres, TX
Mike, terrific and very helpful! Are you taking out the old ports and putting new ones in or just the lenses?
Best,
Sean
Sean, I am taking out the old ports and putting new ones in. The ones from SBO are an exact match. It’s not difficult. I had one that I had to dig a little rot out of the core where the port sits I filled it with some epoxy let it cure then replaced the port.. The other three the core looked like the day it came out of the factory. I have two more 512’s to go and then the single 414 that opens to the cockpit.
Years back I changed the lens on one but over the years the plastic part that makes up the hinge became too fragile. So I replaced the worst one then the next worst one etc.
