how to replace deck organizers 87 Cat 30?
debby
Both my deck organizers have suffered sheive self destruction...I have the replacments which I purchased from Cat Direct but I am clueless as how to remove and install. I was hoping for advice. It appears the nut is under the headliner??
Robert Moretti
no nut
On my 1985 c30, the deck organizers have a single screw running through each of the sheaves. If there is a nut (I don't thinks so), it is permanently in place and not accessible. You should be able to simply remove the screws. r-moretti@northwestern.edu
Don
My c27 has a threaded metal plate ...
that is glassed inside the cabin top. Use some penetrating oil on the screws. Use a big screwdriver to work them back and forth untill they come out. Mine was bedded with 5200, so I had to work around the assembly with a common screwdriver to get it up.
Ron
Deck Organizers
I have a 1987 C30. My organizers a machine screwed in a metal plate that is glassed over on deck. Just remove the screws and replace.
debby
deck organizers
Thanks for the info..seems it shouldnot be too hard..I was concerned because the replacments came with a nut on the end of the machine screws thru the sheives and I was afraid I would have to be able to tighten that somehow!!! Time to get out the PB Blaster for the screws and a big screw driver!!!!!
