How to repair worn screw holes in fiberglass?
Jul 22, 2011
146
Mariner Yacht Co.(NH) Mariner 28 Atlantic Highlands, NJ
As Captain Queeg said, "There's a right way, a wrong, the Navy and My Way!" Take your pick. The right way depends on how you use your bimini, how thick the cabin top is ( whether it is cored or not) and how long you intend to keep the boat. You could get away with just putting in an oversized wood screw. The resons that pop into your mind as to why that is not a good idea wil point to the correct solution. The strongest solution will include a through bolt and a backing plate, but you may not need that much strength. One of the above answers discussed "casting" the screw in the epoxy. If you coat the screw or bolt with mold release, you can easily unscrew it. Epoxy is easy and fun to work with, once you get used to it. While not necessarily the least expensive, the West system is easy to use for beginners, easy to measure and they have some very informative pamphlets. I'd read through the pamphlets before starting. let us know how you make out.
Lou
Nov 15, 2009
29
Hunter 39 New Castle, NH
Thanks everyone. I do not have access for a backing plate and through bolts so I'm now thinking epoxy will be the fix.
Aug 16, 2009
1,000
Hunter 1986 H31 California Yacht Marina, Chula Vista, CA
I cannot help but think that a stainless rivnut is the answer. If one were concerned that the flange the rivnut tool makes is not enough, then it could be sunk in epoxy. This makes the installation almost equivalent to a backing plate where that is impossible because of lack of access while still allowing removal and reinstallation on a "nut and bolt" basis. I suppose the downside is if for some reason one needed to relocate the mounting hole he would have to remove the rivnut and repair the somewhat larger hole it left.
Oct 29, 2005
2,366
Looking at the Mxbon105, it looks very much like Superglue ala cyanoacrylate. Anyone tried Superglue with baking soda for filling holes?
KZW
May 17, 2014
831
Catalina 310 #307 Bluewater Bay, FL
It can work depending upon the stress and vibration. Superglue tends to make strong, but brittle joints. When used with baking soda (much better than micro-balloons IMHO) the final mixture acts like concrete. It is a chore to sand, and very strong, but if you whack it hard, it can shatter.
My preference is epoxy with some baking soda, and cut up fiberglass fibers. Mix it up and pack it into the hole.Slow hardening is better to allow time to work it into the hole and get all the air bubbles out. It is easier to drill than superglue and baking soda, and will be more resilient to vibration.
Sep 20, 2014
1,330
Rob Legg RL24 Chain O'Lakes
Rivnut is along the right idea, but something much simpler would be a threadsert. This way the screw threads are not stressed and the holding force is held by a much larger screw. Since the thread is glued in place, it has less chance of walking around. Threadserts have a much deeper thread, so it will hold much better.
http://www.ezlok.com/InsertsMetal/stainlessSteel.html
When you have access to the back side, then you use a T-nut.
Trying to fill the hole in and repair the original threads is a waste of time. It already broke once because the fastening method was not adequate. Do it right once and forgetaboutit.
Feb 8, 2013
92
beneteau 352 Raritan Bay
My vote is to fill the holes with fiber glass resin.. mix some resin with some hardner and push it in..
Waybad
Nov 12, 2011
25
Skookum 34 34 Custom DesMoines
You can use thread inserts in Brass or Stainless steel. They come in assorted sizes. The fiberglass needs to be a 1/4 inch or more in thickness. You drill a hole for the size of the threaded insert, then thread it in with a screwdriver or a tool which works a little bit better.
I use a small hex head with lock nuts with threads to fit insert. I coat it with your favorite two part epoxy on the outside threads and it is then threaded in to the fiberglass like a sheet metal screw. the insert has a interior thread for a machine screw. Which you can remove at anytime if needed. good luck which ever way you go. Waybad
Jun 6, 2006
6,990
Don't try and glue it, fill the holes with FG resin putty (resin + plain old baking flower to make a peanut-butter consistency). Redrill the holes and install with life caulk to seal out water intrusion.
