how to remove these light fixtures?
4Winds
Jun 8, 2022
53
Hunter 33 Wilmington, NC
I want to upgrade lighting in the rear berth and tie a new Hella fan into the same wiring ...how to get this light fixture off without tearing the fabric around it? I cannot get it off!
4,638
Hunter 46 Point Richmond, CA
Check for a set screw securing the light housing to the plate attached to the ceiilng........at least that is the way they are removed on my sailboat as I recall.
4Winds
Jun 8, 2022
53
I was certain that the face of the fixture must pop off somehow, revealing a base that would be affixed to the panel from the outside (like the other cabin ceiling lights)... but for the life of me I do not know how to twist, turn ... pop the fixture off the plate. That is what I am struggling with.
Sep 22, 2021
314
Hunter 41AC 0 Portland, OR
Ours twist about a 1/4 turn and then just pull away from the base. If I remember correctly, you turn CCW (as if unscrewing right-hand threads).
