Hallo all,
This afternoon I tried to disassemble the two adjustable (rotating)
propellerblades. I would like to check the markings on them because
one does not seem to be attached in the correct position.
So I unscrewed the four allenbolts that tighten the two coneparts
together and the centerbolt.
Standing behind the prop, facing foward, I tried to pull off the
aftcone. But it doesn't move a bit...
I can move the frontcone three cm forward on the shaft untill it hits
the stern.
Studying the Combi overhaul drawings I got the idea that the aftcone
should fall off after releasing the bolts and it should then be
possible to pick the blades out. Is that so ? How to proceed ?
Thanks & Regards from Amsterdam,
Paul
the stern.
Paul
