How to Remove Grey Enterprise Portlight
Sep 27, 2008
252
Hunter 41 Longport,NJ
Can anyone walk me through how to do this ? It's leaking, I can remove the mounting scrws of the ring fromt he inside, but that's about it - I'm told to really stop the leaks I need to remove, cleamn and rebed the entire thing - suggestions/instructions /tips ?
Jim
kito
Sep 13, 2012
2,011
1979 Hunter Cherubini 30 Clemmons
I just took 4 of them out on my H30. Yes, take the screws out from the inside flange. It won't move since there is tons of caulk still holding it in. There should be a trim ring on the outside too. Some people just attach the outside trim ring with caulk and not screw it down too. Anyway, remove the outside trim ring. Gently pry the inside flange up to break the caulk seal (they may have used butyl tape too). From the outside, dig out all the old caulk you can. You should be able to just push the whole portlight through once the caulk breaks free.
p.s. Be very careful prying on the plastic trim ring and flange. Mine where the originals from 1979 and busted into tiny pieces. Probably best to run a thin sharp knife under it first to break the caulk seal. I was replacing mine anyway so I didn't care. Also, do a search on Youtube on portlight rebedding. I found a few good videos of the procedure.
Jan 13, 2011
94
Hunter 33 (78 Cherubini) Aberdeen Proving Ground, MD
Easy task...
I replaced four of my windows with those from New Found Metal. Great service, good price, drilling jig available.
I used one of the five in one paint knives to break the seal. Saved me lots of time. Use a razor blade to clean off the remailing silicone and acetone to take off the residue.
By the third window I had the entire replacement (removal included) down to about one and a half hours.
