How to remove dried teak oil
Feb 6, 2013
437
Hunter 31 Deale, MD
Early last year I oiled all of my interior teak--6 coats. I proceeded on the mistaken assumption that I could clean up the drips later. Wrong. This stuff is tenacious. So I tried various solvents to remove it and finally found one that works.
I applied liberally to keep the surface wet and allow the solvent to work. I used terry cloth and elbow grease and patience. Resist the urge to use a Scotch pad, it will scuff the gelcoat.
Also, this solvent will not damage most plastics (test it first).
BTW, not available in some states. I bought mine at an autobody supply store in Virginia.
Ok, my pics uploaded in reverse order, but you get the idea.
Likes: StargazerP303
