How to Remove Couch in 2005 41AC
Jan 26, 2016
12
Hunter 41 Huntington,
Looking for any help on how to remove couch in 2005 41AC in order to access hoses behind it. I am adding a waste vent filter.
Thanks
Bill M
SV Optimistic
MFD
Jun 23, 2016
244
Hunter 41DS Pacific NW USA
I removed mine on a 2009 41DS. I am thinking the layout and actual couch is the same. A bonafide couch with its own arms on the end and all that. There are a few screws you can see around the bottom after pulling out the drawer there. I ended up putting in a full tabletop cabinet (am a live aboard so extra storage and surface space was well worth it).
Found this 41AC listing with a picture of the interior and couch - looks substantially similar.
If you have the lower drawer thing, slide that out and it can be tilted up and removed. From there maybe a half dozen screws or so.
The important thing being that it is all screws, so easy to remove and easy to put back in.
Nodak7
Sep 28, 2008
1,256
Hunter 41DS Punta Gorda, FL
The next question is how do you get it out of the boat? Jesh it just does not seem like it would fit easily through the hatchway!
MFD
Jun 23, 2016
244
I was able to take mine out single handed. Oddly enough absolutely no recollection how. I might have needed to unscrew the back from the seat portion, not sure. Overall it definitely went a lot easier than I expected, which is the opposite of most things on boats :)
Likes: Johnhen
MFD
Jun 23, 2016
244
I was also able to track down this old thread, which encouraged me that couch removal would be easy.
