How to refinish cabin floor (photo attached)
Michal
Jun 25, 2014
10
Tiara S2 9.2A Woodbridge, VA
Hi everyone,
I need to refinish floor on my S2 9.2A, the old finish is almost gone. Can somebody guide me through the process from sanding to refinishing?
6,244
S2 9.2a Fairhope Al
Hi everyone,
from the looks of your floor..... you need to use a cabinet scraper...its a metal card about 6 inches by 3 inches ..just get on your knees and scrape all the old finish up ...then block sand by hand with 220 grit or may have to use 180 grit...be very careful not to sand through the teak and holly ...ware a mask and use a shop vac ...if you don't know how to use a cabinet scraper google it and you will find something
Michal
Jun 25, 2014
10
Thank you, Woody. I will follow your scraping instructions.
Can you recommend a product to refinish with?
Feb 6, 2013
437
Hunter 31 Deale, MD
I think a vibrating sander would be easier. Mine allows me to switch from orbital to linear. It also has a port to attach a shop vac.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
thats a hard one as there are many out there....i think chris patterson may know of a good one to use ....bowling alley finish is a good one but not sure where to get it ..you can use Helmsman's polyurethane from lowes or hd ...when you clean your sole .....if there are lots of ugly gouges and scars don't worry so much about them as you will never bring that floor back to new ...but it can look good and well kept for a 35 year old boat...if you want new you will have to put new t&h down ...lots of work...oh and don't power sand no matter how hard hand sanding may seem...just do what you can and take a breather or go home and start again the next day ....after all it took a long time to grow the trees and you will just have to be patient...good luck and post pics
Michal
Jun 25, 2014
10
Thank you Woody and IH82BL8. I will start working on it this weekend and update this post with progress photos.
Nov 10, 2012
22
S2 9.2 ST IGNAGE, MI
hi Everyone,
I Need To Refinish Floor On My S2 9.2a, The Old Finish Is Almost Gone. Can Somebody Guide Me Through The Process From Sanding To Refinishing?
On Our S2 9.2a I Sanded Our Floor With A Vibrating Sander, Then Varnished It With Sickens. Also Sanded The Teak Around The Galley And Varnished All The Teak Inside The Cabin. It Looks Great.
Michal
Jun 25, 2014
10
What do you think about using teak oil on wood on top of the cabin instead of varnish ?
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
when you say "on top of the cabin" I assume you are talking about hatch sliders/hand rails/etc. on the EXTERIOR of the boat. In which case I'd probably recommend Semco rather than teak oil. Or maybe Sikkens Cetol Marine. I don't feel teak oil has much longevity. Heard good reports on Semco. My Cetol has been lifting after 1 season. Not happy about that...
Search the forums, many, many opinions regarding teak protectant options.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
what Do You Think About Using Teak Oil On Wood On Top Of The Cabin Instead Of Varnish ?
that Will Work But It Is A Long Process To Use Teak Oil And Get 4 Coats ...has To Dry For 24 Hrs Each Coat And Maybe More Depending On The Humidity
