I would like to get a fishfinder for speed and depth, but have hesitated because of the need to mount the transducer and paddlewheel. I see that some companies such as Humminbird offer a suction cup mounting kit. So my questions are:Does a transom mount work properly on a sailboat? Would my daggerboard cause turbulence and affect the accuracy? Can it be located so that it still functions when heeling?Do any of you have experience with the suction cup mounting system? If not how have you mounted yours? Some transducers can work through the hull, but to get speed you need a paddlewheel which must be mounted in contact with the water.Thanks for your helpRob HumphreysOregon City, OR
