How to make boarding from ladder easier
241
Catalina 36 1430 Lake Lanier
I have a 1983 O'Day 23. When I board via the stern ladder, I have to then cross the hurdle of the rear pulpit rail. This can be tricky,especially when the boat is rocking a a swell.
Is there an easier way? I've thought about cutting the center rail out and putting in a life line with pelican hook so I can get it out of the way. My brother has a concern that this would weaken the whole thing. He suggested cutting it out and putting it back with some sort of hing and fastener to keep the whole thing more rigid when in place.
Anyone have another idea? If not, how would you attach the rail section back to keep it rigid yet still be removable?
Thanks!
Chris Wolcott
s/v Yanqui
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
I'm not sure if I can come up with a solution to your problem except that maybe you need something higher on your stern pulpit to hold on to while you swing your left leg over the rail. I'm assuming that your ladder is on the Port stern.
Years ago when I trailered my O'Day 222 I had a marine welder/fabricator make me up a mast crutch to replace an ugly monstrosity that I made up out of wood and metal. This guy did a wicked nice job in making this this thing up and he made it so it could come apart with fast pins and be stowed in the cabin. I liked it so much that after a while I decided to just bolt it on permanently. I'm sorry I didn't have him weld it but I could do that anytime I guess.
Several years went by and I decided to make a flag pole to stick in the yoke of this hula hoop for my ensign instead of hanging the flag on my backstay. It's worked out great through the years.
When I use my swim ladder I have no trouble getting on or off my boat while holding the hoop.
This is just one advantage. The other advantages are: I can use this hoop with my mast crutch to carry my mast to and from the ramp and also use it as a means to support my main tarp for winter storage not to mention that this crutch mount also enable me to raise/lower my mast with a CDI furler all by myself.
So you may want to look into extending your existing pulpit with something similar. The hoop leans forward a little so that the crutch pipe can sit into a flange on the cockpit sole which takes the weight of the mast while trailering.
Another thing I've neglected to mention is that this hoop is great to lean against when I'm either standing up sailing or motoring my boat.
241
Were your stern rails already two separate pieces that the welder joined, or did he cut off the original center section? When I looked at D&R for 222 stern rails, they look inline, not as if they round a corner like yours do.
My current railing looks like this:
Jan 24, 2005
4,881
Those are the stock rails that were supposed to come with my O'Day 222 but my stern rail is very similar to the other one pictured only because I requested it during the building process at the O'Day factory in Fall River Ma.
I bought my boat at the Boston Boat Show in 1986 and asked the dealer to have the factory install the full stern rail and leave the Gennie winches and tracks off the cabin so that I could install them on the combings. This dealer had a building with a main show room and at least four warehouses with O'Day sailboats stocked in them. Being a large dealer in the Worcester Ma area doing a tremendous business selling O'Days and Catalinas, he was able to pull it off for me. I was even able to visit the factory a couple of times to watch her being built. I'm told by Rudy of D&R Marine that O'Day installed rails like mine on twenty of their O'Day 222s.
My rail doesn't have a bar going across like the one in the other picture. Instead, it has two more bales for a short lifeline cable which I never used. I guess you could say that the rails on my boat are built separate but the shape of the rail is the same as a full stern rail. The way I have it set up right now, it is a full stern rail.
Here's a couple of pics of an 87 O'Day 222 with the same stern rail that the factory installed on my boat.
Oct 10, 2009
1,120
Beneteau 393 Muskegon
We just adapted to climbing over ours and it's always interesting when someone new uses the ladder. We use the transom as the last step; otherwise our legs aren't long enough to make it all the way over. My kids still go underneath the stern rail, but I wonder what will happen when the reach the point when it's too awkward to go underneath, but they still can't step over.
I'd really rather have something like Joe does or even none at all, but it's not worth it right now for me to go through the work required to retrofit a different stern rail. But if you are so inclined and if they are available (and if they fit) I think those smaller ones will make for a nice change.
Jan 24, 2005
4,881
I didn't like those short rails when I saw them on the 222 in the boat show.
I just went outside just now and measured my rails. My stern rail is on 16" high off the combing and the hula hoop is 30" high. I climb the ladder and stand on top of the transom and swing my leg over the 16" rail while holding on to the 30" rail which leans in forward a little bit. Believe me. It's a piece of cake. I think a six year old can do this pretty easy. It's just as easy climbing down from the ladder. The hoop gives me something to grab hold of going up and coming down. Not only that but the hoop gives me enough room to operate my outboard. I like it. I think it's a great set up for my boat.
I had that mast support made up in 1990 and the guy charged me $220 for parts and labor. The only thing I made was the wood mast crutch.
This guy was a good marine metal fabricator. He designed this thing right on the spot. He added the fittings to my rail and bent the pipes. He was working out of his garage back then at his house.
Later on, he and another guy went into business together and had a shop and marina worth millions of dollars. Singer Billy Joel was keeping two of his boats at their marina on the river. Today the business is owned by Bristol Marine. This is a pic I took of one of Billy's boats, a 57' twin diesel.
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
One of my very first projects was to cut the stern rail for easy access and it has worked well for ten years, I noticed this season that the base's need to be removed and some epoxy work done cause over the years of others grabbing the rail and not the back stay has cause a little flex in the deck.....I'm thinking about having a grab rail welded to the vertical supports and the bottom mounted to the stern for extra support
4,881
That's a nice set up RAD. I see that you have a line tied to it in the same way I secure mine. I use a "Highwayman's Hitch" to secure mine to the stern rail just in case I fall overboard I can just pull on the line and it will free the ladder.
Feb 1, 2006
114
oday 22 on trailer Asheville NC
Stern Rails and Boarding Ladder
Hi Trinkka, I like your stern rail setup with the 30" loop over as it seems to make boarding from the ladder easier. Would my 79 O'day 22 main sheet that is attached to the back stay be of any problem w/ a stern rail setup like yours?
I see you have a main sheet traveler in the cockpit, and is this an advantage over the back stay main sheet with the loop over rail? I may search for post on travelers, I think I have seen one you posted in the past not sure where?
Who would be a good source to order a setup like yours?
Thank you, David S
Jan 24, 2005
4,881
Thank you, David S
Hi David,
When I had that hoop made up, The welder made it to be removable by using two fast pins and I did just that until I discovered the advantages of just leaving it on my stern rail. I got rid of the fast pins and bolted it in place for good. Looking back now, I wish I'd have had him weld it in place but that's something that can be done right now if I choose to do it.
Myself,- I love the thing and I think it makes the boat look real cool. It also gives me something to lean against as well as a place to hang my yacht ensign.
The mast crutch pipe sits on a 90 degree 1" base fitting on the sole of the cockpit about 5 or 6 inches in from the transom which needs to clear the self bailing cockpit well. This is why the hoop leans forward. Otherwise the crutch pipe wouldn't be straight up and down.
I don't think a stern rail set up like mine would hinder the end of boom mainsheet attachment to the backstay on your boat but I could be wrong. The only way to find out is to sight it with a plumb bob in relation to a base fitting on your sole or floor of the cockpit. It's important to have the mast crutch pipe sitting in this flange on the cockpit floor when you're trailering your boat to the ramp because of the weight of your mast sitting in the crutch. You don't want the stern rail taking this weight when you're enroute to the boat ramp.
I honestly believe that the traveler offers a better advantage of the back stay set up that my boat came with. Of course, a boom vang can also be of an advantage too. I like this Harken traveler that I have now. I can set it under load and adjust it so that I can get the right angle of the sail in relation to the wind while being able to flatten the sail in strong winds. I find that my boat can sail faster and point up a lot better.
It can be a pain in the butt at times to step over. My wife isn't too crazy about it because she can't sit in the Port seat with her back up against the companionway bulkhead with the traveler in the way.
I started out with a Nico Fico traveler and it was simple and adequate for a small boat like ours. If I had it to do over again though, I'd have bought a Garhaurer or a Harken with the ropes and pulleys.
I bought the Harken off a fellow named George on this forum who lives in West Virginia. He used it on his O'Day 23 when he sailed the Chesapeake. I love it. I should have bought one years ago.
I was able to use the same Teak mounting beam that I had made up years ago for the Nico Fico eye beam track.
Years ago when I mounted my traveler, I needed to mount it on something solid like a Teak 2x4 about 60" long and it had to be made in such a way that it had to be shaped to conform to the curvature of the cockpit seats. I also made it to be held in place by four stainless steel bolts through the seats. I have these bolts set up so that the heads don't turn. I was able to install it by myself. When I was buiding this beam I mocked up one out of cheap pine until I was happy with the way it fit on my boat. Then I made up the final product out of Teak. You never want to practice with Teak. It's too expensive to screw up. I was buying used Teak at a marine consignment store back then and storing it in my bedroom closet so the kids wouldn't find it and practice their carpentry skill with it. :D
Last year, when I bought my traveler off George, I converted it over at the club with the boat sitting at the dock. I was able to remove the beam with the old traveler and bring it up to the picnic table under the trees and remove the old eye beam track and mount my new one. Installing it back on the boat was a snap and I was able to caulk it and install it by myself.
I would check into buying Garhaurer or a new Harken. Each one would be a good traveler for any boat. Rudy sells Garhaurer. http://www.drmarine.com/ I don't know if there is a beam you can buy for the track to sit on. You may have to build one like I did. Here's the sketch that I made up. I countersunk the bolt heads into the wood by tracing them with a pencil. Then I used some crafting chisels to seat them. The I beam track sits on top of these bolt heads locking them in place. These bolts won't turn while you're threading on the washers and nuts making it easy to mount the beam. This construction technique was just one of my few brainstorms that happened to turn out well. I've done some on this boat that I wish I had never done but that's life.
