E
		Ed Schenck
Fall is coming and with it some chilly sailing on the Great Lakes.  I found several postings in the archives regarding expensive diesel heaters.  What do the new Hunters use for heat?  Do the reverse-cycle units like MarineAir work?  Can they be used away from the dock or is their amp draw too high?  Or have you found an inexpensive way to heat the boat?  And not the clay pots over the stove burners,  I have a refrig where the stove used to be.
