How to cover your salon table with a nautical map
2,057
- - Satellite Beach, FL.
Very cool!
Thanks for sharing, I shared your link with the Morgan folks on FB. Hope that's ok?
Jan 4, 2006
7,282
How much depth can you see in the Bar Top Epoxy after you have coated the surface ........ or is this something YOU control when you apply the epoxy ? Also, how resistant is the epoxy surface to scratches and wear ?
I had used System 3 Silver Tip epoxy on several recent projects but found it necessary to rob a bank each time I purchased the epoxy.
warain
Jul 24, 2012
11
Catalina 30 Seattle
great question - you control the depth, for this table I poured a full box of this, (the box is under $30 at home depot) and it only took 1. on my blog post I have a link to the epoxy I used.. depending on what you get, it can get spendy!
you can also "brush" it around to thin it out if you want a thinner look.
Jul 8, 2011
704
Catalina 30 Sidney B.C.
How did you keep the epoxy from ronning of at the rounded corners ?
Going to do my countertops in my 1982 Catalina 30 real soon , already ordered the paper
warain
Jul 24, 2012
11
Catalina 30 Seattle
I actually just let it run over the edges a bit and used a brush to brush the drip marks off the bottom. so that it encased it up to the teak boarders as well as all the way over the 2 rounded corners.
hope this helps!
jGo
Jun 14, 2012
30
Catalina 27 Seattle
Such fantastic timing! That is the first project on my winter TO-DO list and you just gave me the confidence and know how to go for it!
Feb 6, 2012
41
Catalina 34 lake champlain
Hi,
Glad I read that post. The white counter top is not that great looking, and wasn't sure I wanted to make the job to change it.
But this is a great looking solution, we'll do it next spring when weather permit.
