How to calculate approximate midpoint draft depth of a keel/centerboard sailboat
Jul 25, 2018
43
O'day 19 MK-II Weekender Narragansett Bay
I am trying to calculate a theoretical PHRF base rating for my 1983 O'Day 19 sailboat using the following Schell Regression Formula:
R' = 610-8.36*(SA/Disp^.333)+0.0000511*(SA^2)-55*(P/(J+E)) -30.8*(LWL^.5)-602*(DR^2/SA)
where SA= .5*(I*J)+.5*(P*E), and DR is the draft depth
One of the measurements needed for the calculation is for the draft depth (DR) of the keel/centerboard.
Here lies the rub: How to calculate the DR of a keel/centerboard sailboat with 9' long stub keel having an average depth of 4.5" , and a 4.3' centerboard with a 15" width along the center line of the boat.
My first feeble attempt at a DR calculation produced:
DR = 0.5'
by taking the average of the addition of the average stub keel depth x stub keel length
and centerboard length - 4.5" average stub keel depth x centerboard width, then dividing by the average stub keel length.
Is there a more accurate method for determining DR for a stub keel/centerboard sailboat?
P.S. My O'Day 19 is a short mast with rig parameters of :
I 20.68
J 7.00
P 21.50
E 8.30
The first iteration of the O'Day 19 tall mast (built from 1979 to 1980 1/2) has a Portsmouth rating (D-PN) of 95.2, which would give a theoretical PHRF base rate of 241 using the following conversion formula: PHRF = 6 * D-PN - 330.
The scuttlebutt is that no O'Day 19 tall mast has been able to sail to its 95.2 D-PN rating, causing many to speculate that DR used in the Schell Regression Formula to calculate a theoretical PHRF rate matching that extrapolated from the D-PN rate (DR = 2.5', how its calculated is a mystery) is not accurate.
Its rig parameters are:
I 22.00
J 7.00
P 24.50
E 8.30
Both boats share the same 19' LOA, 16.67' LWL, 1350 lb. displacement, 7.75' beam, and 4.3' draft maximum and 1.0' draft minimum.
Joe
Jun 1, 2004
8,342
Whew! Who the heck are you going to race against?
