I am interested in building a hooka surface air supply system. This 2009 thread:
http://forums.sbo.sailboatowners.com/showthread.php?t=109208
has given me some good info. My original intent was for a 12v powered system. Then I realized that the 110v Porter Cable oiless compressor (135psi, 2.6 scfm@90psi, 2HP, 6 gallon) that I have might be OK to use. It is about 7 years old. I wonder if some kind of air filters might make this older tank's air clean enough to breath?
I am not certified, but have done 5-6 resort dives (1/2 day classes each) in Caribbean and Australia as well as being very comfortable under water. My reason for considering this system is so I do not need to continue to free dive to pull the Egeria densa weeds around my dock (they have been getting worse every year. I work in a 5' - 15' depth so with a quick push (or kick) to the surface while exhaling is an easy thing if the hooka system stopped pumping air.
I'd be curious of the components, specs and sources that others have used for air filters, second stage hooka regulators, air hose, check valve, harness, etc. Thanks
